Svo7 plus doesnt home corectly
the fuse blowe on it after buy a new fuse i replcae it to then home it after it was all booted up and it now homes to far to the left cant find anything it fix it help
If you’re talking about the main fuse (on the power supply), you can try to do a reset factory and then redoing the entire installation process, including leveling.
If it’s another fuse, what fuse is it?
it is the main fuse i did as u recommed and it still isnt homing corectly the z is to far to thje left and its how it should be any other tips you have
Can you post some pictures please…
yes of i ment x not z thats my bad but ill get some pictures rq
as you can see they z is fair of where its ment to be and ive look on yt and even asked chatgpt for fixes but havent found any
normal when it homed it the nozzel would be nexztt to the lightingbolt but now it isnt homing near it
Have you loosen any bolts ?
no i havent touched them at all
So, open a ticket at info@sovol3d.com with the order number and theses pics.
Normally, they reply within a week but, right now, it’s the New Year period and it’s closed until February
im a have alot at every part before doing that jsut incase i can fix it and not have to wait ages for a reply but if i cant i guess that the only option i have
Sorry, I can’t help you anymore without knowing what exactly you did on your machine and without seeing it.
I guess you didn’t change the configuration files?
no i havent i didnt even know i could tbf
Sorry, I repeat, open a ticket.
Except if someone else can help you.
Have a nice day
thank you for trying ot help me have a nice day
It’s not Homing because the cable is wrapped around the frame…it’s on the wrong side.
This is wrong:
This is right:
Bravo @Lion,
You have good eyesight. I am unable to diagnose such a defect from such a photo.
Bravo again
Yes - good catch! Well done!
yeah i moved it to where it shoulf be and its still doing it and ive had it like that for 4 months so idk what to do
