SV6 leaving open spacings in second layer
On the second layer printing there are ripples in the surface visible in the picture. If you hold it up to the light there are gaps in those locations. Starting at 1:00 and much more between 3:00 and 5:00.
SV06 200 noz 60 bed pla
Recent error caused complete re-leveling of the machine and a change to a better grade pla
I have no idea what is causing this
Any Help Appreciated.
I have seen this and like you went to the logical culprits, leveling and filament. What fixed the problem for me was adjusting z offset slightly further away from the bed. Hope this helps.
Ihsjepsen
Well its now printing much better. I adjusted the Z up and down which was a big part of it. But also reset Cura to defaults (Draft) and reset everything else.
Thanks for your advice.
The battle maybe own but the war goes on…
Jim
