Sv08 usb connection
After reading around here , it seems the sv08 cannot be controlled over usb?
The intent it to control it with repetier host over usb. If thats not possible, pls advice, so i can send it back.
Welcome.
AFAIK Repetier is Klipper compatible.
Change “Connection mode” to tcp/ip. They, however, want to install their own instance on the host. I’m not sure if the H616 host in the SV08 will let that happen.
Doesn’t the SV08 just use a Text File with the SSID info on it…??
Reperier is an old product from the pre-klipper days. Like Octoprint built to manage multiple printers. Most users are used to connecting to Marlin printers with a USB cable and don’t realize it can also work over wired/wireless ethernet (TCP/IP).
You should be able to by connecting with a USB-C cable after you have set the SW1 DIP Switch to FEL position. As described here: GitHub - Rappetor/Sovol-SV08-Mainline: Getting the Sovol SV08 onto mainline Klipper · GitHub
