SV08 Stops Extruding Mid-Print
In case anyone else reads this and the above comments don’t help, I was having this problem and like the folks said, this sounds like heat creep. My heat creep was coming because the nozzle throat/neck (long skinny part from the top) was not transferring heat into the heatsink. I added thermal paste to the outisde of the neck and inserted it back into the heatsink and it fixed all of my mid-print problems. But I do think that filament resistance plays a role too.
Hi, I’m experiencing the same problem after the update. What did you do to fix it for good?
