SV08 issues
Well I can say when this printer is working , it does a great job . Like I said when it’s working . Since purchase I have had firmware issues out of the box . It would never save z offset from the screen .The taco bed was a pain in the but . The factory nozzle decided to push out of the hot end and gouged my pei sheet . Sovol sent me a new pei sheet a new nozzle and a new bed systems with springs . That seemed to help out a lot . Then the new nozzle decided to leak filled my cover up with petg. So taking the cover off it ripped my parts fan wire off . Sovol replaced the hot end with a new one this one has a set screw and a new fan . Which took over a month to get . Now the port for the fan stays on 24/7 so I was able to change it to fan 3 which klipper can control that but now I am getting sever under extrusion . So I went ahead and ordered the microswiss flow tech hot end . I am still getting under extrusion. I have adjusted the tension on the extruder to no avail Inhave a big order I am trying to get out any ideas I how to fix the under extrusion.
These are the before when it was printing to good to now .
Have you added the pin keeper block to the extruder?
No I haven’t. Where do I find it
From the thread I linked yesterday:
Well between that and a microswiss hot end it’s back to printing thank you
