Hi all,
The fan on the Plus Ace is too loud to have in my living space while I am working and I would like to swap it for a Noctua. I found several mods/cases for the SV06 Plus, but has anyone found an alternative for the Plus Ace? I am happy to look into it myself once I have some time, but being new to 3D printing and tinkering with electronics in general, I’d be pleased to have part numbers and an STL.
Which fan is bothering you, the mother board or the power supply?
I’ve attached a 3mf file for the MB cover (converted from step model at Sovol’s Github). The PS is a metal box modeled as a brick but you could open it up and change the fan fairly easily.
Pic is a GENERIC power supply with the cover off. I marked the fan plug but it could be in a different spot on yours.
Now you have to decide weather to stay with a 40mm fan or cut a hole in the cover and go bigger. 90% chance fan is 24V which eliminates most computer fans from consideration unless you want to deal with a dc/dc converter.
Lastly note the spots where the transistors are clamped to the case. Glue on heat sinks applied to the outside would help a quieter fan keep things cool.
OR search the forums for “mean well” and updrade the whole power supply to a (semi)name brand unit with a thermally controlled fan.
I don’t have a mod, but want to add that the power supply fan on the Plus is much louder than the regular ACE.
I brought it up in one of Sovol’s live streams a few weeks back and they said “they’ll give feedback to the supplier” but who knows if that’ll do anything.
All of the fans on the ACE and Plus are pretty loud though in comparison to an A1.
Part of the noise is…
That because of the ACE’s camera the PSU was moved from the right to the left…
this puts the fan on the bed side & not facing out…JMO
Sorry for the delayed reply. The motherboard fan is super loud and I plan on replacing it, but I am also looking for a PSU alternative. I realize the sv06s often get recommended Meanwell – do the Plus Ace have a similar alternative?
I really like the Plus Ace but the fan sounds like a loud bathroom fan and it’s on 100% of the time. I’ve run the printer maybe 40 hours so far and the MB fan is beginning to be louder than the PSU…
In the case of 3d printers I have seen the power supply is just a “black box” the Motherboard doesn’t even know it exists. ANY device that will supply dc power (usually 24V) to the screw terminals on the board will work.
There are “add on” relay boards to switch off the AC input but as far as I know no Sovol printer has one.
You could put the power supply in the next room and run wires* to the board or use a giant bench power supply.
Thanks for the input, cardoc! I will look into this once I swap the MBU fan for the one that just arrived in the mail. The bearings on mu MBU fan have about 40 hours and are already starting to fail loudly.
Brief update regarding the MBU fan upgrade for the SV06 PLUS ACE. Pics below.
I printed the MBU cover linked above, wired a 80x80x15 mm 4-pin 12 V fan to a DC-DC converter (~24V to ~10V) using two jump wires, and used two more jump wires to connect to the 2-pin header on the motherboard. I adjusted the DC-DC converter to operate at 10V. Cooling is efficient and quiet. I may swap the two jump wires for the 2-pin plug off the old fan. Took about 20 minutes excluding print time. I printed the “hole” version of the MBU cover because I wasn’t in the mood for inserts and have hundreds of zip ties.
Minding the ribbon cable while you swap out the cover was the trickiest part, and I wasn’t aware that you need to turn the adjustment screw on the buck converter counter-clockwise ~20 times before it begins to regulate output voltage..
Wow I admire your dedication to employ an adjustable buck for an already quiet fan.
I I’d have mounted the fan as a puller… Create a low pressure area and air flows smoothly thru every available opening to fill the void. Pushing air through openings creates turbulence and high pressure zones as the air tries to squeeze through.
I’m an amateur and thought it convenient to have the adjustable buck with a display for convenience. Admittedly, it is overkill by a few dollars but I found it especially user-friendly. I definitely agree about mounting the fan as a puller. I questioned whether I should and decided to give it a go with the “nice” side out. I can already feel it nagging at me, so I’ll probably take the five minutes to spin it around… probably this afternoon now that someone has called me out. I’m just happy I don’t have to hear the whining fan that the unit came with. Except now the Y-axis has begun making an awful noise…
I was tired of the PSU fan always running loudly, so I bought a Mean Well RSP-500-24 to replace it. However the dimensions are a little different from the stock PSU. It won’t fit in the same location because the frame brace is in the way. Has anybody else done this upgrade? I wonder how/where you mounted it.
yeah I found this case which fits it just fine, but I haven’t found any adapters for actually mounting it to the printer. It doesn’t fit in the original location. I thought of moving it to the side of the frame, but I think the X-axis stepper motor is there.
I guess for now I will probablyleave it freestanding next to the printer until I come up with a better idea.
