I received my Sovol SV04 in August 2021 and it’s using firmware V1.0.2.
I followed the instruction from the document provided “How to flash the Motherboard firmware on SV04.docx”, but the firmware.bin from V1.1.0 never gets renamed to firmware.CUR. So this process fails.
I have tried to do these steps with different card (SD and Micro SD cards at 8Gb and 16Gb) but every time it failed.
I even tried to used an older version of the firmware V1.0.9 but it still failed.
I am unable to update the firmware on mine, unfortunately mine did not come with an SD card so I am using a 16gb SD card per customer support recommendation however, no matter how I format it or how I name the firmware file it will not update.
I have the same problem, it sort of goes through the process of flashing but never renames the file, even if you rename it.
i also get the odd weird problem when it seem to just stop for no reason at all, so i am wondering if its the firmware not completing successfully.
i would like to put klipper on the machine but it wont flash at all so i know there is a problem.
