Sovol3D Cura_1.7.2_x64.exe
I got the Klipper screen for my SV06 plus and wanted to install the new Cura software which was delivered on the memory stick. The installer stops after about a third of the decompressing and tells me that maybe the installer is corrupted.
Can anybody tell me where to download a fresh Exe?
I tried the installation first in German, and then again in English. Both installatiin produce the same error.
Have you tried to install the official release from Ultimaker ?
Normally it works.
The Ultimaker releases have completely different version numbers.
It doesn’t matter.
I will try it today, see what happens.
I have the same problem. did you find a solution? Can’t find the download online.
Try this:
The USB that came with my Klipper was corrupted as well. Not doing good Sovol, not doing good…
