I recently purchased a Sovol SV07 and from the moment I went to set it up I have had issues. It would heat up and then give the error MCU error ADC out of range.
From watching the printer heat up I realised that this is caused by the bed suddenly reading -50C before the printer shuts off.
I don’t know if this is an issue with the thermistor or the port its plugged into. I went to unplug the thermistor and the port it was plugged into seemed loose, and I don’t know if that is normal or not (I’m not a computer guy).
I was wondering if there is another temperature port I could plug it into to diagnose it as an issue with the thermistor (I see 4 ports that are empty next to where the thermistor is plugged in, but I don’t know their purpose or their pin code if I were to edit printer.cfg). If it is an issue with the thermistor, where could I buy one?
Thanks for your help, this is frustrating. Haven’t got to print anything yet ![]()
