So back in March I decided to upgrade from a Longer LK5 Pro 3d printer to a Sovol sv06 Plus since I wanted a printer that can reach higher temperatures. After I received the printer and printed a few things in PLA+, I attempted to print something in ASA.
After I attempted to preheat the bed to 95 degrees a few times and received an error each time, I realized that my printer is struggling to heat the bed anywhere past 80 degrees. I’ve checked the connections to the motherboard, I’ve replaced the bed with a new one, I’ve tried flashing the firmware, and I’ve PID tuned to see if it affected it at all, but its still not heating up past 88 degrees which was the highest its ever reached. The hot end heats up perfectly fine so its just the bed, I have no idea what to do at this point. Any thoughts on what the issue is or how to fix it?
