Sovol SV06 Plus Auto Home Failed
I keep getting the error message
"Auto-Home failed!
Restart Printer! Check wiring
on end stop switches and
stepper motors for damage
or disconnection."
I can’t print anything nor can I do the auto levelling, I already checked the Z axis and I haven’t seen any problems,
I tried to attach some pictures of my printer to help, but the forum can’t load them.
You can’t upload pics until you reach a certain post limit…most forums are like this.
You can upload them to the cloud & post the links.
Is this printer new…??
If so, did you already send an email to
info@sovol3d.com ?
If not, please send the above situation with videos and pictures and your order number, and they will check with the engineers asap.
Oh thanks.
Yes, I bought it around May from this year, but I only assembled it, I did try to print a box once, but it didn’t work, and I haven’t used ever since
Does it move at all, what about the X & Y…??
A video would be helpful.
Thanks very much, I’ll do that
I have the same problem, and would like to add the following detail.
Mine seems to do this when I have printed directly from Ultimaker Cura via USB cable. When I print from an SD-card it never seems to do this.
I haven’t solved this yet, but perhaps this detail will trigger a thought in someone?
