Here are two issues with my Sovol SV04 printer. I’ve seen these ever since I received the printer over a month ago. Does anyone know if this can be fixed?
Sovol SV04 Auto Home Fail #1
Sovol SV04 Home Button Fail #1
Sovol SV04 Auto Home Fail #2 and Home Button Fail #2
After cleaning out a clog on the right extruder my S04 came up with an error screen “Auto Home Failed” (see attached) When I try to print the heads are out of alinement far to the right, about 5-7 cm, to the point where in dual or mirror mode the right head is printing off the bed.
I haven’t been able to find a way to rest the printer to factory setting as error message suggest
Any assistance you can give would be greatly appreciated
I’m having a similar issue where after I level the left extruder in tha AUX Level menu, when I push the #2 extruder, the head goes back and for a split second and then gives the above “Auto-Home Failed!” error message and I have to restart the printer.
