Sovol 02 use only extruder 1
At time I would like to use only extruder 1 on the sovol 02, how do I slice so it recognizes only extruder 1?
Hello Adstaggs
How to do this will depend on the slicer that you use.
If you use Cura, you just need to right click the item that you want to print and then select Left Extruder. (See screenshot below)
I hope this answer your question.
