After some severe stringing on my right extruder during a print (used the left for the print, right for ‘tree’ support), I decided to make a quicky stringing test setup. A vertical pair of 2.5mm posts spaced 35mm apart. I then tried four different filaments I bought from Sovol. No comments needed on the quality, good or bad, as the tests I did do not appear to be tied to the quality or anything else about the filament.
The left extruder produced ‘fuzz’ occasionally but no little to no stringing between the ‘towers’ using a range of temps. But the right extruder did consistently at all temps. The issue at hand is how it did the stringing. As you can see in the pic, the stringing happened in regular, discrete Z steps. This is the first stringing I’ve seen on the right extruder. Any idea what’s gone wrong?
I forgot to mention that I was using the Sovol ‘brand’ of Cura. The settings for the left and right extruders were identical and using the default settings throughout.
The nozzle on the right extruder was changed out several weeks back as it was clogged, but appeared to print well after that.
Are you using the Cura that comes with the printer - 1.5.6 or whatever?
There’s Sovol profiles in some of the latest versions of Cura. I’m using 5.6.2 for my Sovol 06+
