I have a problem with the code generated by Cura for a double extruder impression. I want to use the right extruder with PVA to print the supports. Every time I need to clean the heatbreaker that it’s clogged.
After some study I discovered that when the machine finish a layer of supports and changes to the left filament, the extruder sends back a lot of filament and it clogs. I have a value of 0.8mm of retraction in Cura 5.3 but this retraction at the change of extruder isn’t afected.
I took a gcode and after study I discovered that everytime that the machine changes, it retracts 1.6mm. I checked that it isn’t the double of the retraction. Although I select “no retraction”, it retracts the 1.6mm before to cold a bit the hot end. This so long retraction clog the heatbreaker everytime that it finish a support layer and change to the print extruder.
Anybody know how to change this value in Cura? I checked the printer parameters, all the options,… and I need a “normal” retraction and not this 1.6 mm value, at least working with PVA that it’s very soft, elastic and very adherent.
