How to I change the M600 command generated by Sovol Cura without editing gcode every time?
In regular Cura, with a filament change script added, the M600 line reads:
M600 E30.00 U300.00 X0.00 Y0.00 ; Generated by FilamentChange plugin
in Sovol Cura it reads:
M600 E30.00 L300.00 X0.00 Y0.00 ; Generated by FilamentChange plugin
That L300.00 generates a purge of 300mm after new filament load!
I can’t find a setting to automatically change the purge.
