Reset print
Hi @sovol3d i have a problem,
i bought my sovol sv06 on leboncoin
And it worked during more than 6 month and suddenly
On the panel it say me “bed printer halted please reset”
So i go on the forum and i solve the problem BUT during print
It stop and did like there’s nothing appens. (sorry my english isn’t vers good).
PLEASE HELP ME
It will read in the log the reason it paused, so getting to that file will be the first recommendation so we can recommend a couple things to look at.. but that process will be completely different if you have the klipperized version or not.
On klipper the fastest way is to log into the printer over the network with Fluidd, and then save the log file. If your not set up to access over the network, you can likely copy it to a flashdrive from the screen.
For not, enterM928 Newlog.txt then try print something till you get the error, then enter M92 to stop logging, take the SD card out and put it in your computer, then copy the file “Newlog.txt” from the SD and attach the file to a forum post so we can read it.
Thks but i’m french and now, i’m dismanteling m’y extruder because it’s broken
Et alors, que vas-tu ou veux-tu faire?
Acheter un nouveaux hotend kit et le remplacer
Tu peux trouver tous les accessoires liés à cette imprimante ici:
