Printing PA12-CF10?
Does anyone have some tips for printing PA12-CF10? I bought this printer for some big projects and the first one needs a filament I have never heard of let alone used. I attempted to print some small items but the auxiliary feeder seems to not be able to pull the filament out of the Sovol dryer box. I also get “nozzle clog” faults although the nozzle is never clogged. I started with a .8 nozzle but the print calls for a .4 nozzle.
Have you printed enough “normal” filament to understand the quirks and limitations of your printer?
False “nozzle clog” faults are an issue for lots of folks. Make sure the PTFE tube exiting the buffer is not constrained in the X axis. It MUST move up and down for the buffer to function.
