Printer Problems
Brand new begineer here.
Was making my first few prints when my printer crashed itself into my hot bed, it took a few seconds before I turned it off. However after replacing the nozzle I’ve noticed that the printer bed is offset by quite large amount. As shown in the picture above it wont stay level and prints come out weird. Is there anything I can do to fix this?
Re-do the entire leveling process, the Z, bed level & Z-offset.
Redid the calibration, fixed everything.
Thanks for the help!
Glad it worked out.
Since you are new…70% of printing issues are this. So many users get stuck on just leveling the bed & skip the rest. You can level the bed all day long, but if your Z-offset is wrong or you Z Axis is off, your going nowhere.
Remember, every time you change the nozzle you have to re-level & check the Z-offset.
The rest is…10% extrusion issues & 10% filament issues (too hot or too cold) & 10% adhesion issues (dirty bed nothing or bed too cold).
Anything else is usually a clog or a broken part.
Good Luck.
exact same thing happened to me i dint. i could do that yet before i returned mine
