Print not working
My print is getting caught on the nozzle of my 3d printer. This my first 3d printer.
You provide too little information for us to be able to help you.
I don’t even understand your problem.
Z offset adjusted? Clean the bed with hot soapy water in your sink, I even lightly scrubbed mine with the green abrasive side of the sponge. Also I found you need to adjust first layer settings to get a good adhesion, up the flow rate turn off the fan … I found that switching to Orca Slicer the default profile does a good job of tweaking the first layer. After that you could also try glue stick on the build plate, I run the stick around then spray it with alcohol and smear it around. Watch some youtube videos.
