Print fails in the same place on blinkfox sample file everytime
Finally got the printer calibrated and teating the cube went well even the dual cube. Went to print the dual_blinkfox_PLA and it is doing absolutely great to start but 3 prints have all failed and in the same place.
The front foot prints but the ankle doesnt. The rest of the print looks great. The foot is still where it needs to be. How do i keep this from happening?
You said you have calibrated the printer, but what about the filament.
What temperature, speed, retraction and so on ?
Hello POINTMAN,
first of all, welcome to the forum.
It seems that you have been trying to print the “Dual_blinkfox_PLA.gcode” file from the SD-card which is an example that has been sliced for the two filament samples that came with your printer. Judging from your image it seems that the filament you used needs higher temperatures. You will need to slice the files from the “blinkFox” example folder with matching filament settings in order to get better results.
Good luck
Björn
