Print can't use the whole bed
I was attempting to do a single nozzle (nozzle 1) print that used up a good portion of the SV04 bed, but found that it won’t use the rightmost portion of the bed and stops about 4/5ths of the way across. The nozzle is able to navigate that far when I use the manual controls to move it there via the touch screen, so there’s no mechanical issue. I thought it might be a firmware issue, but I’m running the most recent firmware offered on the Sovol site. The print looks just fine in Cura when I slice it and I’ve had no issues with copy or mirror modes.
Has anyone else encountered this issue?
What slicing software do you use? Is the print size the same as in the picture? Could you upload the gcode file for analysis?
