New setup mcu buffer Unable to connect
I have purchased a Sovol SV08 MAx.
When I start up the printer for the first time I get the following message.
mcu buffer_mcu : Unable to connect. Once the underlying issue is corrected, use Firmware_restart.
Does anyone know how to solve this problem?
I’m not sure if this issue has been fixed, but there are two discussion threads on this topic on this forum.
I recommend that you read them first.
After, if it’s not enough, don’t hesitate to repost.
BR
Pull off the toolhead cover & make sure there are no loose wires/plugs.
Problem solved
Disconnected cable
