So I’ve had a Soval Sv06 plus with a Klipper for a few years now. For the last year and a half I’ve had a consistent issue with the bottom of prints being only lines and not flat no matter what I do.
I’ve tried redoing the firmware, replaced the nozzle, replaced the whole extruder, switched programs for my prints, everything I can think of or find online and nothing works.
I’ve narrowed it down to the only possibility being that the nozzle just won’t get close enough to the print bed. The real issue is that when I try and calibrate it the extrude will lower until a certain point and then when I press the button to send it down again it just does a little jiggle but won’t move, and from there it will no longer go up if I tell it to in the calibration.
I have no clue what’s going on and at this point I’m wondering if it’s just better to give up on it and look into getting a different printer if I manage to save up for one. If anyone has experienced something similar or has any ideas to try it would be much appreciated.
