Had the SV06 for a couple of days and have this error. Will not do anything now. All connections appear to be ok. Set up correctly and using default settings. Printed fine yesterday but this morning has the error. Please help.
Thermistor error…
You can switch the hotend plug with the bed plug on the board to see if it moves to bed.
If it does contact Sovol for a replacement, if you can’t wait you can by them on Amazon.
What temp did you set the nozzle for when the error showed…??
