I installed my klipper screen on my sv06 plus and had it working fine, all of a sudden after turning the printer back on the screen is stuck in this startup loop, and all the files from the flash drive are gone! I have no clue what to do. Sovol has not responded and i am not able to find any info on how to fix it! can someone help me please!!!
Good morning
I have problems too, random errors, blocking. Operation under Klipper is not explicit enough, I reverted to the original Marlin firmware for the moment where I have no problems. I sent a message to Sovol, but no response yet
Same with the Klipper Screen on SV06 Plus, after shutting down or restarting the printer, printing is not possible: Error “Save_last_File”. After manually deleting the file list, everything works fine until the next restart/shut down.
Is there a way to factory-reset the klipper screen?
Newb here, but it worked for me.
Download the firmware and follow the instructions provided in the zip file
scroll down and you will see the firmware, which is posted on Google docs.
[SV06 Plus Klipper Screen Firmware - Google Drive]
BTW, I tried numerous times to update the firmware using the right USB port on the Klipper screen, just for the heck of it, I unplugged the USB that goes from the klipper screen to the control module on the Soval 6 +, and it worked.
Not sure if I missed that in the instructions somewhere or what. Good luck
