Ciao amici , ho bisogno davvero di aiuto!!! Avevo installato klipper su sv06 e dopo molti tentativi è cambiata scheda madre sono riuscito a far funzionare il tutto , poi ho comprato la sv06 plus per costruire pezzi più grandi ma togliendo klipper dalla sv06 e mettendolo nella sv06 plus mi ha memorizzato le dimensioni della sv06 anche cambiando nome al firmware…mi sono approcciato da poco alla stampa 3d e se avete la soluzione a questo problema ve ne sarei davvero Hi friends, I really need help!!! I had installed klipper on sv06 and after many attempts it changed the motherboard I managed to make everything work, then I bought the sv06 plus to build larger pieces but removing klipper from the sv06 and putting it in the sv06 plus it memorized the size of the sv06 even changing the name to the firmware… I recently approached 3d printing and if you have the solution to this problem I would be really grateful!!!
It sounds like all you need to do is download & install the SV06 Plus Klipper & re-flash.
Dear friend, thank you for the courtesy you have given me but since I am ignorant on the issue could you tell me precisely the things I have to download! I tried but at the moment I don’t understand anything! I’m trying to learn but I need someone to guide me!!! Cq Thank you very much
I’ve never installed Klipper, but if you scroll down the GitHub page to " Klipper Installation",
It gives you a walk through on what to do.
Hello
I have tried many times to install Klipper on a Rapsberry PI 4 but it does not work!
i still get an error when i want to connect the serial port i get an error 255.! The firmware copied to a micro SD does not work the SV06 no longer connects the firmware I waited for two minutes nothing happens!
I don’t understand why the Bin file is not working.
Suddenly I reloaded the original fair and the SV06 plus works fine again with MARLIN.
If you have any idea about the problem I abandoned the project.
Francis
Bonjour,
J’ai essayé toutes les solutions proposées impossible à connecter le port série. j’ai toujours la même erreur 255 j’ai abandonné car j’ai passé beaucoup de temps à modifier (make menuconfig) à trouver le bon paramétrage du port série rien n’y fait c’est un gag.
J’ai copié le fichier BIN sur une micro carte SD la SV06 ne lie pas le firmwaire.
Conclusion j’abandonne
