OK so I designed this part which has some overhangs which need support, but also has a lot of round holes in a gently outward-slanting surface which absolutely do not need support. If I turn on supports, I get a support for every hole – even if the support angle is 89 degrees. There’s also an arch that gets an unneeded support. But if I turn off supports, I don’t get the supports I actually do need.
Seriously it thinks I need a support HERE?!? https://prnt.sc/ZQ4Ptju0aC4_
I can’t show you the version with the hundred supports for circles because I already worked around that by changing them to hexes – pointy top.
Then let’s talk about adhesion for the supports. For those on the outside of the model, that’s fine – they sit on the brim I specified, which is expended to include them. But the model is hollow and for supports that end up in the middle, they are just a tiny blip with nothing around them on the plate, and they come loose during printing.
Image: https://prnt.sc/9keeH9jNhrCL
How can I not edit individual supports? How can I not specify an allowed length for an unsupported span? Do y’all actually use this program or is there something better you would recommend?
