Internal error on command:"SAVE_LAST_FILE"
Hello, i have this error on my SOVOL SV08 MAX
Internal error on command:“SAVE_LAST_FILE”
Internal error on command:“SAVE_VARIABLE”
Can you help me please ?
Thanks
Have you checked if you file system is full?
yes it is not full i have erase all files
the pb appears juste after the plate is at the good temperature, at the end of the heating
Maybe a corrupted file system?
Please upload your klippy.log
ok how i can do that please ?
i have found , here is my klippy.log
i can’t send you the file because i am new on the forum :smiling_face_with_tear: how i can send you the file ?
You can use an upload website or Google drive using a link
here is
https://drive.google.com/file/d/1NdKDAONanmXZkck6jp8Lam-IAGpKL4zY/view?usp=sharing
Only 243 lines came through…
Try zipping it first then put on google drive.
OR run it through here:
https://sineos.github.io/Klipper-Advanced-Log-Inspector/#configs
And examine the extracted “shutdown logs” yourself.
the file in zip
Is it good ?
Still only 243 lines and no errors
Reboot your printer and attempt to start a print. If/when it errors use fluidd or mainsail to download the updated log from the printer. Zip it up and post a new link.
Maybe not this issue, but might be something to also check.
I was fighting with something similar on my Sovol Zero. I found changing to “filename:” and checking the saved_variables.cfg file was present got me past the “save_variable” error I was seeing at one point while I was debugging my issue.
Oddly “filename” is the only parameter in printer.cfg that does not use a colon at the end of the parameter. Klipper mentions they are both supported, I don’t know why the difference. I’m new to the 3D printer world and am still learning about the deeper parts of configs.
Anyway, I changed the following in printer.cfg for the save_variables filename parameter.
[save_variables]
filename =/home/sovol/printer_data/config/saved_variables.cfg
to
[save_variables]
filename: /home/sovol/printer_data/config/saved_variables.cfg
Some related references I used when debugging:
Github links to printer.cfg and the save_variables files.
printer.cfg
saved_variables.cfg
Klipper KB about which parameter style will work.
Sections and Settings
Cheers,
-Mike
Oddly the SV08Max configuration on Github uses the “[space]=” convention:
[save_variables]
@bats33 Have you made any edits to your configuration?
Hello thanks very much, i have found a solution with IA GEMINI it say me to put in printer.cfg
#[save_variables]
#filename =/home/sovol/printer_data/config/saved_variables.cfg
and in macro.cfg
[gcode_macro SAVE_VARIABLE]
description: Neutralise l’erreur d’ecriture EMMC
gcode:
Ne fait rien, evite le crash
[gcode_macro save_last_file]
description: Neutralise la sauvegarde de position PLR
gcode:
[gcode_macro _SAVE_PRINT_STATS]
description: Neutralise la sauvegarde des stats
gcode:
But i don’t have PLR now!
I think that it is a bug of sovol after i have flash my EMMC
