After approximately 24 hours of printing, this error pops up on the screen and in Klipper.
Fortunately, it doesn’t stop, and printing continues. This has already happened twice.
Any ideas? Should I check something?
It sounds like a klipper file corrupted.
Have you changed anything in your klipper configuration?
Otherwise, a firmware corrupted?
Hello
I have only added the auxiliary heating module.
I had serious problems with the wifi and I got new motherboard but switched the eeprom from the old because of Sw version problem.
Then I still needed to fix the linux side to get wifi fixed(keep online).
Does anybody have the link to the newest 2.1.9 file or what do you propose?
Have you taken a look here?
Here is the beginning of an answer:
Can you please make a packet from the newest SW and share it.
Can’t you update OTA to 2.1.9…??
This new motherboard came with 2.0.9 but I could not upgrade it with OTA..do not now why. It got stuck instantly. That is why i changed the Emmc from the old one. Is anybody succeeded?
The machine needs to be connected to the internet to upgrade to version 2.1.9 via OTA. Did the network connection fail?
