On assembly when I try to use the touch screen it is off by about 10mm to the left.
This becomes an issue when trying to enter numbers in manually for temp etc as I cannot press the Enter or Escape buttons.
I did a google which suggested connecting via a usb and Pronterface / your software and run a M995 command (Touch Screen Calibration | Marlin Firmware).
This did not work as I got the error: Unknown command “M995”
Looks like I might need to reflash and ensure TOUCH_SCREEN_CALIBRATION is enabled?
Thank you
V
