How to stick Asa and Nylon to the bed?
the printer comes with the Pei surface, but do i have to use some stick glue to properly stick Asa and Nylon to it? (Asa even seems to be harder to stick?)
i currently have the bed leveling issue, where it just starts to print in mid-air, but do i need some glue too or not? and Nylon starts to remove the white line color from the bed once you are able to start printing?
I only used ASA, not nylon.
My recommendations are as follows:
  • printing in enclosure,
  • nozzle temperature 245°,
  • bed temperature 100°,
  • a little bit of 3Dlac or dymafix (not mandatory),
  • wait until the bed is very cold to take off the object (<30°).
With this, I have no print failures.
maybe i just need an actual heated tent(and 120*c bed) for some manuf filaments and others can do without?
I noticed this morning that you have 4 threads going about different things…
You need to get your bed leveled before you do anything else…your z-offset is till not set right…JMO.
Except if you use a very specific filament, it’s not useful.
BTW, unless you make it yourself, does it exist?
For printing ASA:
nozzle temperature 270°,
bed temperature 108°(> vitrification temperature)
And add capton tape on bed.
I use standard ASA, but i can print at 150mm/s (first layer:30mm/s)
Add border width 10mm to 20mm
fan 5%
