How to restore Klipper on this printer
I had a very bad idea. I tried to install Fluidd on this printer.
The result: my Klipper is broken and Moonraker is unreachable.
Does anyone know how to reinstall Klipper on this printer? I haven’t been able to figure it out.
And I promise I won’t do it again.
Thank you in advance.
If you can get in with SSH I’d try using kiauh and uninstalling then reinstalling everything first.
You’ve nothing to loose (except time). Sovol’s flash process will work just the same even if Kiauh makes it worse.
WINscp will allow you to backup (copy) your printer_data folder (if SSH works) if you do it before you do the flash.
Back to business.
My printer works again.
Thanks for your help.
