The BL touch got stuck in a print for some odd reason. The touch sensor is now inside the housing. Is there a way to get it unstuck from the housing?
Sovol 06.
Use a hex wrench to loosen the top wire on the side of the proximity switch, the position is shown in the figure
It snagged on a print. The print was completed and somehow when it went to back to 0,0 it hit part of the print.
Thanks! That got it unstuck. Looks like everything back to normal. Successfully completed a print. Have to readjust the z offset tho.
glad to hear that! Have fun with the printer ![]()
