Hi gang, I had a meltdown and had to pull the head apart to clean it. After cleaning and reassembly I need to adjust the nozzle offset to the BL Touch. I’ve watch a bunch of videos but none show adjustments with the touchscreen. I’m at a loss. Any help will be much appreciated.
Hello Lowlock,
Refer to the second minute of the video: How to install bl touch and auto-leveling on Sovol SV02 - YouTube, the models are different but the adjustment method is the same
This is the touch screen manual: Touch Screen User Manual.pdf - Google Drive, there are simple instructions for adjusting the z-axis compensation value
Thank you
Sovol Team
