Hello
I had had some problems with PLV blocking in the extruder. when I solved this portable, the home positon of extruder dont work anymore. The x axis is shifted to the left for more than 7cm. when I push home button the X axe motor continue working while the axe is at the limite of its position.
How can i solve this problem.
Thank you
hi @nkobra It would be much helpful to analyze if you don’t mind adding a photo of the issue.
I found the solution
The cable of extruder was detached and that causes the no detection of end of line by the LED of X axis moteur.
Just putting back the cable solved the problem
Thank you
