HELP…Sovol klipper muc unable to connect error! Please advise…I’ve reloaded .bin file, many times,
If you want to be helped, try to give us as much information as possible about your problems.
- What are the issues?
 - What did you do?
 - What do you want to do?
 - Firmware version?
 - Slicer?
 - And so on.
I installed the bracket/ lcd screen on my SV6+.Copied the cfg.bin
File to 8gb sdr. Installed power cable, hooked usb cable from controller to controller. Put sdr in slot turned it on
And waited for it to install…got a menu setup WiFi it’s connected…then I got the MCU cannot connect screen
Turned off restarted, same issue. Follows screen prompts restart firmware…still same mcu screen.
Tried the reboot to original setting… I’ve been running in
Circles for days.reading no online…all I want is to get his going…if successful I’ll upgrade my SV06 next…
If it’s a standard installation that doesn’t work, I suggest you open a ticket on info@sovol3d.com with your order number and your previous explanations.
Is this the Sovol Klipper Screen or something else…??
The Sovol Klipper Screen comes with Klipper Pre-installed, there is no install setup to go through.
