my printer was working well until all of a sudden this started happening
I’ve taken it apart, cleaned it, greased it
moved where I place my filament
put a space heater in the room in case it was too cold
changed the nozzles, even increasing size to .8
tried multiple different print files
multiple different filaments
changed out the hot end, and the extruder it’s self
I’ve done every physical thing I can think of
Every large fix I’ve tried only has ever managed to get me roughly 1.5 hours worth of printing before it fails again
after a few tries to fix it and with the new one I’ve even had trouble getting the filament to retreat without sticking
the last fail I had to take the whole thing apart just to take out the filament because it wouldn’t go down or come out the top
one of the suggestions was that there is a problem with the firmware but I can’t find a link to the update and I’ve seen some people say it bricked their printer which I definitely don’t want
I use the cura slicer, I’ve tried the prusa but it I can’t get it to work right at all
the alternate extruder even leaves gear groves on the filament
my firmware I have is V1 1.5
marlin version 2.0.9.2
don’t have a pic at the moment, but I’ve tried it in different spots since the original set up that came with the printer kept failing, my current set up was working well enough to print a 3 day long print (longest I’ve done) with no issues before this happened, I’ve also preemptively pulled a bit down so that it couldn’t catch and it’ll still do the bending when the filament above the extruder is totally loose
There are two possible problems I can see here:
1: The heat break has something clogging it. Mine sometimes gets clogged with a peice of rice, because I use rice in one gallon zip lock bags, to keep the filament dry when I am not using it.
2: There is not enough cooling on the extruder. A lot of people mod the SV06 and SV06+ printers, by replacing the stock 4010 extuder cooling fan with a 5015 fan: https://www.youtube.com/watch?v=zzE6iBIE4JM
