Extruder Problem with SV08 MAX
whenever i try to do a big print the extruder says its stuck and there might be a clog and just stops printing. I have cleaned the whole tool head countless times and have hand fed fillament and it extrudes fine. It even printed a benchy but when i try to do anything large it just stops working. I was wondering if anyone else also had this problem
Welcome,
Your problem is likely with the feeder (AKA buffer) near the filament roll holder. The buffer is supposed to push filament into the long tube that goes to the toolhead.
If you go back and read through this forum you’ll find LOTS of discussion and tips & tricks.
Lets us know if you still have questions after reading that info.
I replaced my feeder with an infinity flow s1 no more feeding issues. That said, I have not been able to get this printer to print good since it arrived. good Luck
