Recientemente se me wstropeo el hotend izquierdo, lo he cambiado y me marca -15,
desconecte el derecho para conprobar si era error de la placa, al conectar de nuevo el derecho, ahora tambien me marca error en ese
So are you saying you swapped them and the error followed from left to right…?? …or…
you swapped them them & now you have an error in both left & right…??
At first it was the left side only, i disconnect the right side to test the new hotend to see if it was a problem in the hotend or the thermistor, but also in the right side was not giving me measure. Then I connect the right side again, and now both sides give me the error of -15 degrees
Was this a Sovol bought replacement…??
Read this, it might help a little.
yes, it was a Sovol replacement, I make the mistake to buy sv06 hotend, but the problem is that the right one also stop to work without reason
I’m so sorry for being so damn stup… I finally find the problem, the cable from the side, the black long ribbon was disconnected and didn’t transmit the information to the mainboard, so problem solved
