Hi all, I did a reboot on the controller on the terminal via SSH. Ever since then I am getting this issue when I start my printer - mcu ‘rpi’: Unable to connect. I have looked through the logs and this is the error mcu ‘rpi’: Unable to open port: [Errno 2] No such file or directory: ‘/tmp/klipper_host_mcu’.
Any ideas on how I can fix this? Thanks in advance.
I was able to bypass this issue by commenting out any lines related to the rpi mcu in the printer config file. However, this means I am not able to use the accelerometer and for some reason my webcam isn’t working either. Still looking for a way to correct this.
