Eddy problem
Hi everyone. If anyone has encountered a similar issue—I can't seem to solve mine. I installed an R3MEN graphite bed and a Sovol enclosure, along with a drag chain. I recalibrated the Eddy (Sovol) probe and performed all the necessary steps for a new bed installation. Now, the bed mesh looks good and the first layer is excellent, but during the Eddy scanning passes, the layers appear sharply raised—resembling those old paper hand fans.
I had never seen that before.
What do you use as a bed? A sheet of corrugated metal?
I’d expect your printhead is loose on the mount plate. I tips back and forth depending on which direction it is moving.
grafitni krevet je ravan, to su samo losa ocitanja eddy sonde a neznam zasto. dobro je pricvrcena sonda. prvi sloj je odlican. printa bez problema. trebao bi ostaviti tako, ali bi volio znati koji je razlog takvog skeniranja.
It looks like the Z range of those ripples is quite small. It is curious how consistent they appear to be across Y for each point in X. It almost looks desirable like how corrugated roofing takes greater loads with less deflection than a flat sheet of the same gauge.
da. krevet mi je prilicno ravan 0.1 do 0.15 samo ti cudni artefakti na svakom prolazu eddy sonde. ako stavim 15x15 isto je naravno onda ima samo 7 tih kanala
pet, 14. kol 2026. u 18:49 Todd Allen <notifications@sovolforum.discoursemail.com> napisao je:
