Does the 3D print speed need to be slowed for ABS filament?
I want to 3D print parts for my 3D printers with ABS filament. I have not printed with ABS filament before. Do I need to slow the 3D printing speed?
I print ASA at pretty much the same speed as everything else 60mm.
You just have to make sure you add a brim of at least 8-10 lines.
Also, you will have to adjust your cooling fan speed, raise your bed & nozzle temps.
This should help you get started:
https://3dprinterly.com/best-abs-3d-printing-speed-temperature-nozzle-bed/
