Display corrupted, flashed firmware and replaced display
My display corrupted about 6mos ago. I purchased a new display before researching. The new display did not change anything, however research, I flashed the firmware which corrected the problem. The display slowly started to corrupt again until it was completely corrupted and I couldn’t read anything. I tried flashing the firmware again with the update. It did not correct the problem. I switched out the display, still corrupt. I am not sure what to try next, but I need to get my printer working for Christmas projects.
Did you already send an email to
info@sovol3d.com ?
If not, please send the above situation with videos and pictures and your order number, and they will check with the engineers asap.
I did not, thank you for the information, I will do that now.
It’s possible that the cable or motherboard is shorting something out.
As posted by @mich0111 put in a ticket with Sovol.
Thank you, I thought about that I could swap out a cable from another machine. Thanks again
