Disassembly problem with top frame
I’m having a problem. When I try to take the top frame off on my Sovol SV08, it won’t come apart. The two front areas where it connects to the Z3 and Z4 supports, it only lifts about 5mm before stopping. They lift the first 5mm easily. After that, it’s like they are locked in place somehow. The back Z1 and Z2 slip off no problem. Is there a way to unlock these, or do I just pry them off?
Fixed it. Just had to pry.
