Difficulty installing the AB axis assembly
I’m having trouble getting the AB axis assembly to fit. It seems slightly too long (front to back) to fit between the Z-axis blocks. If the front goes down to the mounting surface the rear hits the top of the Z-axis block and won’t go down to the mounting surface. I have tried repeatedly to get it to fit by carefully lowering it into all 4 corners but it will sit on top of all 4 mounting Z-axis blocks in that case :frowning_face:
Do I have to remove the top frame, loosen the Z3 and Z4 corners, and pull them slightly forward for this to fit or is there some adjustment I can make to achieve that?
Won’t it be too tight once everything is tightened up again?
Thanks in advance - I’m looking forward to getting this going!
I tinkered with it a bit more and then went ahead and loosened it up as I described and fit the AB axis assembly in place. It went together just fine. Since then I’ve printed a Benchy and it appears to work just fine!
