Cura for SovolSV08
I have had the Sv08 since august and still can’t print anything but the Benchy that comes preloaded on the SD card (even then it took till today to finally get it to work). SV04 I have had little bit more luck (cause I can use cura to print) but even now that won’t level. But I cant find any Sovol cura for the SV08 to download all of them don’t have an SV08 option and do not want to use Orca slicer as I already have an Elegoo 4 Max that I use Cura for and dont want to learn how to use another slicer that is not easy to use. The Elegoo 4 Max has been printing pretty much 24 hours a day since January and only took 1 day to get it up and running great. Does Sovol even offer the cura for SV08 and when I use their website for downloads and support there is no option for firmware or anything for the sv08.
There isn’t an Official Cura profile as of yet…but,
You can add one from follow this:
https://the3dprinterbee.com/sovol-sv08-cura-settings-profile/
Hi, I am wondering do you know that on the red memory stick that came with your printer the SV08 their is programs that you can put on your pc or Mac that will allow you to control your printer and slice models etc. The program are called Cura and another one that you need to load into your pc is Mainsail. I knew absolutely nothing about either of these programs until I got the SV08 a few months ago. Give them a go I am sure you will pick it up quite quickly.
