Connectors type
It would be nice, if someone can share with me the exact type of the connectors in the USB connection line: Toolhead board, Frame male and female, Mainboard.
Many thanks in advance.
Thank you so much. But which JST Series connectors we are talking about?
@sisa I generally keep these JST connector kits around for projects. They match most of the connectors I’ve run into on the Sovol Zero. I don’t own a SV08 MAX, but looking at the pictures of both boards, it looks like they will work.
I’m not sure what kind of connector is used for the CAN1/2 on the posted SV08 MAX board, Dupont 2.54mm of some sort?
JST connector List (Amazon Links, probably cheaper elsewhere)
JST/Molex PicoBlade 1.25mm Male/Female 22AWG pre-crimped silicon wires.
JST-PH 2.0mm Male/Female 24AWG pre-crimped silicon wires.
JST-XH 2.54mm Male/Female 28AWG pre-crimped silicon wires.
On a side note, I find these JST-PB 1.25mm to Dupont 2.54mm useful for breadboarding with the JST-PB 1.25mm connectors.
Cheers,
-Mike
