During printing model( model in attachment and also the time lapse until failure) at some point X and Y offset instantly got so bad (diagonal around 100mm) that printer head started to repeatedly hitting printer frame very hard. I would like to know if I’m only one with such failure and if you aware of why this could happened. Alongside with this topic I send email to Sovol.
On a core XY “lost counts” on either the A or B motor will result in a diagonal shift.
The root cause is the nozzle colliding with the print. The question is was the collision severe enough to actually stall the motor or did something “slip”.
Check the grub screws in the belt sprockets on both motors.
Double check belt tension.
If both are good then you need to examine the model and print process to minimize curl/warping of the part. Z hop might help but is slows the printing process.
When you tightened your belts did you put the X rail the same distance in mm as in the video or at the center point? If you had a longer span than the video and tuned to the same frequency as the shorter span your belts are too tight an could damage the motors and belt rollers.
@sovol3d where is the belt tension info for the Max?
thanks for your insight! when you say check the grub screws, what are you looking for in terms of just that they’re not protruding? and they tighten with a normal wrench? I’m having mechanical problems on prints and it was recommended I look at these grub screws - how would I do that without completely loosening the belts? or it’s assumed I would do that first? thank you for your time
