Broken pieces on printer that I need to replace
I found two plastic parts had fallen from my printers head but I’m not sure what I need to get to repair this. There’s a flat square plastic piece and a warped plastic cover. Do I need to buy the complete “Planetary Direct Drive Extruder for SV06 Plus” from the store or is there something else that needs to be bought to repair this?
Alright, the top of the fan & duct are missing. I use a different cooling fan on my SV06 & SV06 Plus, but I have the original parts to show.
This is a standard 4010 fan, but you will have to solder the wires to use the old plug.
You can print 1 of these 3 ducts…ASA/ABS would be great, PETG would work, PLA will not.
or if your up to it, replace the whole setup with something like this:
You can also email Sovol at info@sovol3d.com and ask if they have a fan setup for you…include this link in your email.
@sovol3d
The fan cover and lower fan duct are (AFAIK) not available to order as service parts.
A replacement fan would have the the cover already installed. It is a generic 40x10 turbo fan if you are willing to splice wires.
The lower duct could be printed
Body1.stl (128.3 KB)
Indeed, these are not spare parts that we can order, but Sovol can probably send them.
@sovol3d
Thank you for the great help, I’ve been able to download a replacement dust cover to print and get replacement parts from Sovol, including some spares in case I need them again in future. Thanks again everyone for the links and advice.
